I got in the car this morning and the diplay will not go past the Jag logo in my 2008 XKR.
Although the a/c will not diplay, the blower motor speed is adjustable and it appears to get warmer and colder with the corresponding buttons. I pressed the on-off button and home button but no response. Blutooth would not do anything.
Where do I start looking?
Lothar52
close
- Join DateSep 2012
- LocationColumbus, OH
Liked:446 Times in 299 Posts
Drive it to dealership and have them check your battery....Originally Posted by SynySTR
I got in the car this morning and the diplay will not go past the Jag logo in my 2008 XKR.Although the a/c will not diplay, the blower motor speed is adjustable and it appears to get warmer and colder with the corresponding buttons. I pressed the on-off button and home button but no response. Blutooth would not do anything.
The battery is always my first "go to" but the cranking speed seemed normal. No struggles to start at all. Everything else with the car is perfect.
Nearest dealer is 60 miles from the house and I needed to be at work on time today.
I will start diving in to the fuse panels tonight.
bobdr1
close
- Join DateFeb 2013
- Locationflorida
Liked:71 Times in 44 Posts
if you have a battery charger , charge the battery fully and see what happens, suspect it will fix problem, if it does, next time it happens go out and get an AGM batttery.
WhiteXKR
close
- Join DateApr 2010
- LocationArlington VA USA
Liked:3,019 Times in 2,141 Posts
Quote:
The voltage can drop too low for some of the electronics (actually, usually during cranking) long before you sense any change in cranking speed.Originally Posted by SynySTR
The battery is always my first "go to" but the cranking speed seemed normal. No struggles to start at all. Everything else with the car is perfect.Veteran Member
Ngarara
close
- Join DateMay 2013
- LocationLondon, UK
Liked:1,136 Times in 799 Posts
Almost certainly battery-related, though it may be a one-off glitch. For future reference: in order to reboot some of the electronics modules, just switching the car off & restarting isn't enough, because it stays in 'convenience mode' with many of the modules still powered on. However, if you stop, get out and lock the car, most things power off. When you unlock, they reboot.
