Here we go again - Electrical Quirk PB and TOP
Old Mar 3, 2023 | 03:15 PM
MudDog's Avatar
Default Here we go again - Electrical Quirk PB and TOP
It all started after a 2 month forced storage due to medical issues.
Car was on battery tender at 13.7 the whole time.
Pulled the car out of the garage and immediately got PB failure , Cruise not available, and now the Top will not move and its never given me a problem.
Windows are acting weird, Power top to go down , windows go down but will not come back up.
I got all the schematics and manuals. It sounds like a ground issue , and if anyone has an idea where to check it would help.
I pulled the backseat junction box and looked things over with no real luck.
The PB failure happened last year and I replaced the control module which seemed to fix the issue.. Now here I am again.
The actuator functions correctly when I unplug the connector and apply power to the GW and RW leads , then reverse them.
Because if the actuator was causing this Id just Blow the car up. You have to pull the K member to change that thing out. NOT Happening.
Any ideas ?
Old Mar 3, 2023 | 03:34 PM
kj07xk's Avatar
Even on a maintainer, I’m guessing a battery can go bad. Two months isn’t long, as mine sits for usually 4 months over the winter on a maintainer.
Get the battery tested before going nuts on other things. (First check its resting voltage yourself.)
Old Mar 3, 2023 | 04:18 PM
sov211's Avatar
The battery is indeed the most likely culprit despite being on the battery tender…how old is the battery?
Old Mar 3, 2023 | 05:18 PM
MudDog's Avatar
Brand New ish , maybe 3 months standing voltage is 13.1 on maintainer 13.9 Full Size Battery.
Starts, runs fine, Run Scan and about half the DTCs come back with Lost Contact with PB
Old Mar 4, 2023 | 12:30 PM
MudDog's Avatar
Weird car ,
Did the battery disconnect, touch cables . Did the PB brake calibration and all went back to normal. Drove Car all Good, Except Top will still not respond. Back windows are down and top refuses to go either way.
Got back in car. Started Up , Immediately Got TPMS System failure, not a low tire but System failure,
Go figure.
Old Mar 4, 2023 | 04:47 PM
MudDog's Avatar
Originally Posted by MudDog
Weird car ,
Cleared the code as scanner said it was intermittent.
But what I did get when i scanned the folding top module was a CODE U303-1 Permanent. Google says Battery Circuit.
Im Stumped. I did a manual top down per the manual , released hyd pressure , pulled the release lever an the top manually went down, AFTER I had a hard time getting the Cover to unlatch but it finally did..
Only to find it would not latch to reclose.
Snake bit.
Go figure.
Just updated to include more info .
OldCoot
Oct 15, 2021 03:26 AM
BuckleSpring
Sep 1, 2018 08:55 PM
Owsley9
XJ XJ12 ( X305 )
Jan 7, 2015 10:55 AM
hammy
Aug 17, 2013 01:12 PM
simplesimon
Apr 30, 2008 10:41 AM
