high beam switch
Old Nov 23, 2014 | 02:18 AM
kj217's Avatar
Default high beam switch
when i pull the high beam lever, the high beam works fine but, it stays on eventhough the lever is back in center position. i need to push the lever lightly toward dashboard until high beam shuts off. high beam also sometimes goes on while turn signaling.
what do i need to replace or repair?
Old Nov 23, 2014 | 12:00 PM
sov211's Avatar
If your car has the active headlamp system what you are seeing with the turn signal is the cornering lamp coming on as well as the headlamp itself moving in the direction of the turn once the steering wheel is turned.
There is probably nothing wrong with the headlamp high beam operation - the detente might be a bit soft and you are probably going past it when you pull the lever.
afterburner1
Dec 16, 2015 12:12 AM
redrover41
23
Sep 25, 2015 01:33 PM
jagent
Sep 12, 2015 09:10 AM
avern1
Sep 8, 2015 06:25 PM
laserguy
Sep 3, 2015 02:02 PM
