Improve FM radio reception on Jaguar XKR 2010?
Old Jul 10, 2016 | 02:14 AM
Nosferatu's Avatar
Default Improve FM radio reception on Jaguar XKR 2010?
There is no visible antenna on my model.
When I'm in the city, I have no problems with FM reception, but outside is like the apocalypse has killed almost all radio stations.
I have the Alpine option.
Is there a fix for this?
Old Jul 10, 2016 | 11:37 PM
Stuart S's Avatar
The XKR antenna is hidden inside the rear spoiler on the trunk (boot) lid.
FM reception depends on the power of the station, the height of the FM tower, and obstructions to that signal. Because FM signals follow line-of-sight and do not reflect off the ionosphere (as do AM signals), on fairly level ground that means FM reception of up to 75-100 miles from a transmission tower. When you drive your car into a valley between mountains, you will probably lose your FM signal because you are out of the line-of-sight. In large cities, tall buildings can also block FM signals. If you're in the mountains, signals will never make it over the pass no matter how close you are to the transmitter if line-of-sight is blocked.
The ideal FM antenna is as high up as possible and always aimed on a straight line from the receiver to the station transmitter. Obviously, cars don't have very good FM antennas because they're always moving and are too close to the ground.
The best fix is to listen to something else. There are never any reception problems when you listen to CDs/iPOD/USB/Bluetooth. Satellite radio, however, is affected by weather conditions.
Old Jul 12, 2016 | 03:16 AM
Nosferatu's Avatar
I know about the FM propagation, the problem is I can compare on the same roads with my other cars.
Jaguar is by far the worst receiver.
Yes, use my iPhone with BT emiter...
Old Jul 12, 2016 | 06:47 AM
jagtoes's Avatar
I have found this to be the same in my 2012. The FM reception is much better in my 2010 Lexus while listening to the same stations in the same areas. I assume it is the design and the location of the antenna. For those with the external antenna do you have the same issue.
Old Jul 12, 2016 | 07:27 AM
kj07xk's Avatar
So far, I'm diggin' the exhaust tune too much to ever turn on the radio.
I actually bought a spoiler from an '08, so I could pull the fuse for the whip, but like I said, I haven't found myself interested in turning on any tunes, other than the exhaust, so I haven't changed out the spoiler yet.
I did look inside the newer spoiler, and the circuit board that has the antenna traces on it, is pretty small, so I can see why reception may not be so good.
jagfour
F-Pace (X761) / C-X17
20
Oct 4, 2016 06:23 PM
Msterieus
Jul 26, 2016 03:10 PM
jrb53
Jun 22, 2016 11:27 AM
vkng7
Jun 18, 2016 12:03 PM
David's XKR
Jun 10, 2016 07:09 PM
