Intermittent misfire multiple cylinders P0300 P0304 PO306
Old Oct 20, 2021 | 11:54 AM
trkyam's Avatar
Default Intermittent misfire multiple cylinders P0300 P0304 PO306
Sorry if this has been covered, I couldn't find the solution by searching.
Recently changed serpentine belt, car really seems to accelerate and shift better and smoother.
intermittent misfires in cylinder 4 and 6, strong gasoline smell from exhaust
when I pulled over. After scanning for error codes all I got was the 3 misfire codes.
After restarting the car, all is back to normal and I continue on my way.
This happend 2 days in a row on cool mornings.
65k miles currently
Can an old battery cause misfires?
Can a loose gas cap cause misfires?
Old Oct 20, 2021 | 12:25 PM
trkyam's Avatar
Is this indication of injector failure in the near future?
Old Oct 20, 2021 | 01:32 PM
trkyam's Avatar
Found a TSB on this, apparently if misfires are only on cold start and engine temp is below 76c (which mine is)
this is due to PCM calibration issues and needs a software update.
https://static.nhtsa.gov/odi/tsbs/20...18162-9999.pdf
(applies to 5.0 engines)
Also my car is running Quantum tune which could amplify the issue.\
I will warm my car up to >75c before driving off in the morning and report back.
Old Oct 22, 2021 | 02:45 PM
trkyam's Avatar
Update: The issue has not come back, however I did put a bottle of royal purple injector cleaner
in the tank just incase. Bad gas is also a possibility.
Old Oct 23, 2021 | 05:20 AM
I should have read this more carefully.
I thought 'cold start' was refering to an air temperature below 76 deg F but it is actually a coolant temperature below 76 deg C (167 deg F). Regardless of where it is in the World, that's not a cold start, it's a warm start. 76 deg C must be the coolant temperature parameter at which, from a genuine cold start, the engine revs drop from elevated to normal.
As the TSB makes clear, no recall to fix an identified software issue - only take action if a customer complains.
Old Oct 23, 2021 | 03:35 PM
trkyam's Avatar
Correct, thanks for clarifying.
Being in Hawaii, Im probably on the cusp of
that threshold very often, being a daily driver.
Jeffrey David Benson
Feb 9, 2022 11:31 AM
Madscott
Sep 7, 2020 06:20 PM
Whiskey Bravo
Mar 13, 2018 02:18 PM
yaknuts81
May 9, 2017 05:28 AM
earthdogjim
Mar 24, 2017 04:18 PM
