ipod cable to new iphone
Old Jul 5, 2017 | 09:30 AM
Michaell's Avatar
Default ipod cable to new iphone
I have a Jaguar XK 2010 with an iPod port and USB port for USB sticks but not a port called Aux. I'm not sure which cable I should get:
https://goo.gl/otKJg7 Jaguar XK + Aux to lightning
https://goo.gl/ex2rKj Jaguar XF to lightning if it works on XK as well
Any ideas or better suggestions?
Thank you!
Old Jul 6, 2017 | 10:05 AM
davchr's Avatar
The XF to lightning cable that you have listed above might work as the connectors look correct. Not sure about the other one. The problem I see with it is the lightning connector they are using will interfere with most cases for the iphone.
I bought an Apple P/N MD824AM/A cable from ebay for about $20. It plugs into a Jaguar P/N 9X23-19H461-AA cable that plugs into the iPod port in the car. This Jaguar cable came with your car originally.
I set up the car and iphone to work together, which is kind of a PITA. I have used them together about once. I put all my music on a USB stick and don't have to mess around with the cable and iphone. The ipad port will not power or charge your iphone which is a problem on long trips.
Old Jul 6, 2017 | 10:27 AM
tampamark's Avatar
I don't have input on the cables you linked, but I do know that non-genuine parts sometimes do not work properly.
My car had the Jaguar provided cable which terminates in the old Apple 30pin connector. I bought a Ebay 30pin to Lightning connector which worked on every device EXCEPT the Jaguar cable. I bought the genuine Apple 30 to Lightning adapter and voila, worked like a charm. I have switched to the Tune2Air WMA1000 which is a bluetooth connector that attaches to the Jaguar cable, it retains screen control of the Apple phone wirelessly and introduces Bluetooth audio streaming.
You could give the Ebay cable a shot certainly but know that it may or may not work. I would get the genuine cable and WMA1000 and be done with it...
