Lazy passenger (LH) side mirror
Old Mar 3, 2025 | 05:16 AM
alanroberts50's Avatar
Default Lazy passenger (LH) side mirror
Mirror usually retracts ok but doesn’t always deploy fully during unlocking sequence. Bit of a squeaky nylon sound and a partial deployment sometimes. Is there a way to get some lube in there onto the vertical hinge without a complete mirror strip down? ( not that technically proficient)
Old Mar 3, 2025 | 07:07 AM
guy's Avatar
guy
You may find that the oxidation (rusting) of the aluminium armature is hampering the movement.
Protect the paint on the door, and give it a good shot of a cleaner. Move it back and forth a few times, Rinse, then apply the lubricant.
WD-40 is cr*&(^p.
Old Mar 3, 2025 | 10:35 AM
Cee Jay's Avatar
Graphite spray is what I use for such things, no greasy residue to attract dirt.
"Passenger (LH)"??? In Los Angeles???
Old Mar 3, 2025 | 04:19 PM
Thanks Guy, where should I be spraying? Just on the outside or is there a way to get it more directly onto the hinge?
Old Mar 3, 2025 | 04:23 PM
Agreed for graphite spray.
yes LH but not in LA this cat in South Africa with the big game
Old Mar 4, 2025 | 06:19 PM
guy's Avatar
guy
If I recall correctly, I had better access by removing the cover.
Old Mar 7, 2025 | 06:12 AM
I think this may be resolved… managed to get some spray into the gaps in the plastic and it appears to have stopped squeaking now when it deploys. Thank you for the contributions.
denis4x4
May 5, 2023 07:28 AM
gehad
Aug 18, 2022 03:09 PM
edreddy
Apr 14, 2022 03:20 PM
Jagjustin
Apr 1, 2015 07:28 PM
LarryK
Mar 24, 2008 09:39 PM
