Len
Old Sep 20, 2024 | 08:28 AM
Lendurante's Avatar
Default Len
I’m new to the forum and have just purchased a 2002 xkr for my wife. The car is in excellent condition for its age. I will enjoy working on it and doing the necessary repairs as they occur. It only has 45000 miles on it and am curious if I should change out the timing tensioner with that low amount of miles.
Old Sep 20, 2024 | 10:05 AM
RichardS's Avatar
Welcome to the forum. As you have a 2002 model it must be an X100 rather than an X150 so it would be better to get your question moved. However, I believe that the improved tensioners had been fitted by 2002 so, with only 45k miles, I don't think that replacement is necessary unless there is some rattling going on.
Richard
Old Sep 20, 2024 | 11:15 AM
Lendurante's Avatar
Default Len
Thanks for the response. I’ll look under x100
Old Sep 20, 2024 | 03:05 PM
kstevusa's Avatar
A portion of the 2002 4.0L had the 3 Gen tensioners ,but it depends when the engine was manufactured, not the car. Just pulled the Right Cam Cover and visually confirm typed. The Gen. 2 were not acceptable either. Gen. 3 are metal. The Gen.3 were in the 2003 4.2L forward.
Old Sep 20, 2024 | 04:24 PM
RichardS's Avatar
I seem to recall that the spring is the key. If the tensioners have a spring on the shaft, they are the latest type.
Richard
Goosemanoose
Feb 14, 2022 11:45 AM
85nova
Nov 19, 2018 10:32 AM
tanngo
Dec 4, 2012 01:47 PM
mjlaris
Oct 15, 2011 09:55 PM
