Mina Gallery Grille HELP
Old Jun 8, 2012 | 08:53 AM
SocalJag's Avatar
Default Mina Gallery Grille HELP
Just came yesterday without any installation instructions...anyone have a step by step that could show me what to do? Thanks all...
Old Jun 8, 2012 | 05:16 PM
axr6's Avatar
Yes, Mina does not spoil you with instructions for that grille. No big deal, use the stainless screws to mount it into the present grille.
I used 8 of the provided screws, starting at the far left and the far right and moving inside. I advise that you pre-drill the holes into the factory plastic mesh. Make sure that the holes are at the crossings of the mesh for maximum hold.
My greatest problem was to find a small enough phillips screw driver to drive the small screws. Make sure you have one that fits the small heads tight as you do not want to round off the phillips heads. The heads are just large enough where it will not go through the mesh and, at the same time, small enough where you can not see them from any distance following the installation.
Good luck,
Albert
xjrjag
Oct 24, 2024 03:09 PM
xjrjag
Oct 12, 2015 03:16 PM
XJ8JR
Oct 2, 2015 12:13 AM
XJ8JR
Sep 11, 2015 12:31 AM
