No power to the doors and central locking
Old Jun 6, 2025 | 10:26 AM
Radek Sadowski's Avatar
Default No power to the doors and central locking
After replacing the battery, the windows, mirrors and central locking stopped working. The electric seat adjustment on the door works fine. Any ideas?
Old Jun 6, 2025 | 10:43 AM
XKDreams's Avatar
Is the battery fully charged? It should read at least 12.4 volts.
Old Jun 6, 2025 | 11:25 AM
Cee Jay's Avatar
I think you have a typo, the required minimum is 12.6 volts.
Old Jun 6, 2025 | 11:41 AM
It is fully charged the car starts normally. The mirrors don’t fold, and the switch panel is not illuminated. Everything else works as expected.
Old Jun 6, 2025 | 11:48 AM
Cee Jay's Avatar
Perform a Hard Reset as it is the fastest and easiest way to solve myriad problems;
Remove both batter cables from the battery, touch the cables together for several seconds without using any connection to the battery.
Reinstall cables to the battery.
Reset window travel.
Old Jun 6, 2025 | 01:59 PM
Will try tomorrow and report back.
Old Jun 7, 2025 | 09:27 AM
It work thank you so much!
Old Jun 7, 2025 | 10:40 AM
Cee Jay's Avatar
I do accept Venmo...................
Old Jun 7, 2025 | 10:44 AM
Now just need to sort out the adaptive headlight fault. The driver side (uk) is pointing down and inside and the asf light on the dashboard is flashing. Any ideas?
Old Jun 7, 2025 | 11:07 AM
Cee Jay's Avatar
Swap the housing modules left-for-right and see if the fail follows the module or stays with the housing. Could be either that module, the housing is jakked, or the main module but I forget where that is.
Old Jun 7, 2025 | 11:24 AM
Thanks Cee Jay. Will give it a go.
Old Jun 7, 2025 | 12:06 PM
McJag222's Avatar
Check the ground lugs for corrosion - located behind the front strut on the chassis. Easy check, jack up and remove the wheel.
Old Jun 7, 2025 | 12:20 PM
Cee Jay's Avatar
^^^ That too, I forgot about it. I'm in a desert and don't have corrosion, so I don't remember it's a thing sometimes.
Old Jun 18, 2025 | 12:17 PM
Hi Cee Jag and McJag222
i have swapped the afs modules (the black box attached to the headlight) from right to left and the fault has followed the module. Would that indicate to a faulty asf module? I have ordered one on eBay, do they need to be reprogrammed?
Also I have taken the wheel off the other day but there’s no grounding cables in the wheel arch 🤔
Old Jun 24, 2025 | 09:03 AM
Any views anyone?
Old Jun 25, 2025 | 01:37 PM
Cee Jay's Avatar
Any views anyone?
Yep, that'd be a bad module on the housing itself. It's an easy fix, just replace what you already did.
Sorry, I've been out of the country for a week.
Old Jun 25, 2025 | 01:39 PM
Thank you!
Old Jun 25, 2025 | 02:31 PM
Hmm just did that and now both are looking straight with my old module whereas previously one of my modules seemed ok and the other one was looking done and to center
Old Jun 25, 2025 | 03:43 PM
Cee Jay's Avatar
You MAY have had a bad connection in there somewhere. You may want to get some of that electrical contact cleaner stuff and clean both sides of all the connectors. You may have lucked out.
Old Jun 27, 2025 | 06:46 AM
Do you know if the asf module needs to be coded or programmed?
