O2 sensor fault
Old Apr 24, 2025 | 05:39 PM
DJK's Avatar
DJK
Question O2 sensor fault
after 3 trips to the advance zone for the correct fitting O2 sensor without the correct fit. I'm willing to try cleaning the original. Is it worth my effort or not?
Old Apr 24, 2025 | 07:45 PM
Cee Jay's Avatar
Before you do that, try swapping the sensors side-to-side, see if the fault moves with the sensor. If not, your catalytic converter may be done.
Old Apr 24, 2025 | 08:13 PM
DJK's Avatar
DJK
The cat was replaced about 1200 miles ago , suffered an internal involuntary disassembly. Unknown if the sensor was also replaced at that time. I’ll perform cleaning, reassemble and then swap test if necessary .
Old Apr 25, 2025 | 08:25 AM
Cee Jay's Avatar
I've never had success with cleaning an O2 sensor. Of course I've only tried it a couple times though.
Old Apr 27, 2025 | 10:26 AM
sony2000's Avatar
Would one clean an O2 sensor, with oven cleaner?
Old Apr 27, 2025 | 12:06 PM
Cee Jay's Avatar
I used fuel injector cleaner, non-diluted. It worked for at least awhile although I can't remember for how long. Maybe even until I sold that car???
I'd be up for oven cleaner, a failed one can't get any more failed...
Old Apr 27, 2025 | 08:09 PM
ram_g's Avatar
Should be able to get correct aftermarket replacements at Rockauto. Your local parts shop probably doesn’t see a lot of Jaguar owners.
Captain Bob 369
XJ40 ( XJ81 )
Oct 25, 2023 07:40 PM
Jagtony
Oct 13, 2013 03:25 AM
tallblondeguy
Sep 17, 2009 06:02 AM
