Parking sensors stay on then in reverse.
Old Nov 19, 2016 | 02:20 PM
powerhouse's Avatar
Default Parking sensors stay on then in reverse.
This last few days when i engage reverse the parking sensors give off the warning noise even when there's nothing behind the car. I haven't used the pressure washer near them at any time. It has been bad weather here for a few days, i cleaned them of but it hasn't cured the problem. Ant ideas
Old Nov 19, 2016 | 03:46 PM
kj07xk's Avatar
What does your display show?
Does one area appear to show a stronger signal? if so, that would be the sensor to focus on.
Old Nov 19, 2016 | 03:49 PM
tberg's Avatar
My front driver's side front sensor stays on any time I'm in reverse unless I'm backing up down a steep incline. It drives me nuts, so I just turn it off when reversing. No dirt or obvious damage to the sensor.
Old Nov 19, 2016 | 04:03 PM
powerhouse's Avatar
Funny enough i never looked at the display, must do that tomorrow.
Old Nov 19, 2016 | 04:54 PM
Cee Jay's Avatar
Maybe the actual sensor part popped off inside and left the trim piece in the bumper cover?
Old Nov 19, 2016 | 05:31 PM
powerhouse's Avatar
Elaborate a bit more on that Cee Jay, where and how to find this
Old Nov 19, 2016 | 06:39 PM
Sean W's Avatar
Does the 07 have front park assist?
Old Nov 19, 2016 | 07:05 PM
Sean W's Avatar
I'm not Cee Jay but the sensor is held to the bumper cover by 2 clips. If the clips come loose it can trigger them.
Constant beep means usually one of them is malfunctioning (high resistance, short to ground, short to power, etc.) There is also the control module itself.
Check the screen to see which sensor is giving you the problem. There are specific DTC codes for each sensor as well. These would be Jaguar specific so you won't find them with a generic scanner.
To access them, you need to remove the bumper cover. Sometimes the problem is just corrosion and you can try to unplug, clean and apply some dielectric grease to each sensor. You really need IDS to know the specific problem with the system though.
There is a button on the roof console that allows you to disable I think.
Old Nov 19, 2016 | 07:49 PM
bocatrip's Avatar
My front parking sensors will not operate unless I push the overhead button to enable them. Is that the way they are designed to work? The rears always come on in reverse but the fronts don't come on in drive.
Old Nov 19, 2016 | 08:12 PM
jagtoes's Avatar
Yes that's the way they work. Quirky type of design. If you back up first they will then work but if you just want to check your front you need to press the button.
Old Nov 19, 2016 | 10:43 PM
kj07xk's Avatar
I think it was part of the 'technology package' option that included the 'adaptive cruise control '. I don't have it, but it is described in the owner's manual.
Old Nov 20, 2016 | 11:00 AM
Sean W's Avatar
From the repair manual:
PRINCIPLES OF OPERATION
If a forward drive gear is selected when the vehicle ignition is first switched on, the front parking aid sensors (if fitted) will not be operational. If reverse (R) is the first gear selected after the ignition is switched on, both the front and rear parking aid sensors will become operational. If a forward drive gear is subsequently selected, the rear parking aid sensors be switched off by the control module but the front parking aid sensors will remain operational until vehicle speed increases above 16 km/h (10 mph).
Parking aid will only become active if the following conditions exist:
Front and rear sensors fitted
• Ignition on
• 'Park' is not selected
• Parking brake is released
• Vehicle speed drops below 7 km/h (4.5 mph) - rear sensors only
• Vehicle speed drops below 7 km/h (4.5 mph) and control switch pressed - front sensors only.
Rear sensors only
• Ignition on
• Reverse gear selected for more than 1 second.
