Is it possible to play the music from one's phone when hooked up via Bluetooth?
Old Dec 31, 2020 | 12:51 PM
  #41
Bill Mack's Avatar
Originally Posted by Yus
I tried the Bovee 1000 in my 2009 XK Coupe and it didn’t work with my iPhone 8.
I was informed after purchase that it would work with an iPod; which I don’t own!
I would question what you have been told. The Bovee is as I understand it simply a Bluetooth receiver. The iPhone has a Bluetooth radio built in, so it's a transmitter. Both the iPhone 8 and the Bovee 1000 can use a Bluetooth streaming protocol called A2DP, so there should be no reason for the Bovee not to receive streaming audio transmitted from the iPhone. As far as I know, you don't need an iPod, just the Bovee (connected to the car) and your iPhone 8. One form of the Bovee has a female 30-pin connector, which is often called an "iPod connector" so maybe this is where the mention of the iPod came in.
Do you still have the Bovee? Is there a connector in the car to which you can attach the other end of the cable that came with the Bovee? If so, the rest should be Bluetooth pairing and connection, and you're in business.
Old Dec 31, 2020 | 12:57 PM
  #42
davemv2002's Avatar
Originally Posted by George Abitbol
EDIT: I meant "is it possible to play..."
The title pretty much says it all: I have no aux / usb input on my 2006 stereo, but of course the bluetooth connectivity is still there...hence the question: could it be used to circumvent that limitation and play the music that's on one's phone? Or is it just restricted to phone calls?
Thanks for the info!!
I listen to audio on my car radio via an external/fm transmitter adapter also on my Ford bluetooth radio (SYNC). My earlier Panasonic dvd player/blue tooth radio will only play from cell phone.
Old Dec 31, 2020 | 01:08 PM
  #43
tampamark's Avatar
Originally Posted by Bill Mack
One form of the Bovee has a female 30-pin connector, which is often called an "iPod connector" so maybe this is where the mention of the iPod came in. Do you still have the Bovee?
FYI, the Bovee 1000 he references is the 30 pin connector style designed to hook on to the Jaguar IPOD cable, it has no other output option. In previous instances it has been found to be very sensitive to proper cabling, in the case below a guy simply bought an Ipod adapter and fixed his Bovee issue:
Bovee/iPod undocks and redocks every 10-15 minutes... help! - Jaguar Forums - Jaguar Enthusiasts Forum
Old Jan 1, 2021 | 04:24 AM
  #44
robi's Avatar
It should work, you just have to get them connected wirelessly
Old Jan 1, 2021 | 07:32 AM
  #45
Yus's Avatar
Yus
Thank you Bill, for all of your makes sense answer!
I’ll order another Bovee 1000 and give it another try!
Old Jan 1, 2021 | 07:46 AM
  #46
Bill Mack's Avatar
Happy to help. The best way to thank someone is to click on the button on the post that helped.
mullisrd
Mar 13, 2025 06:45 AM
Diminiko
Mar 25, 2015 10:56 PM
drak24
Jan 26, 2015 06:58 AM
