Possible starter failure?
Old Aug 21, 2021 | 07:06 AM
Mikehill596's Avatar
Default Possible starter failure?
Hello All,
Ive gone to start my XKR to take for its annual MOT and its failed to start. I get a clicking noise as if the starter is trying to bring the cat to life. Ive checked the battery and plugged it into my CTEK, all fully charged. The issue is still there, does this sound like starter failure?
Old Aug 21, 2021 | 10:38 AM
Check cable integrity and tightness of connections at the BJB (Battery Junction Box):
Clicking suggests the Starter Motor isn't dead.
Old Aug 21, 2021 | 10:50 AM
Thank you! All appears in tact with no obvious signs, I guess the next step is replacing those mega fuses?
Old Aug 21, 2021 | 11:06 AM
If the fuse had blown you'd have no signs of life at the Starter Motor. With the BJB connection good and tight, check the other end at the Starter Motor for the same.
Even though you believe the battery to be good and fully charged, a jump with another using the emergency connection studs could be worth a try. The negative jump start connection is a stud located in the spare wheel well.
Old Aug 21, 2021 | 11:43 AM
Thanks, will wait for the weather to dry up then have a dig around.
Old Aug 21, 2021 | 06:42 PM
jagtoes's Avatar
Sounds like the starter solenoid doesn't have enough power to push the starter gear to contact the 12V power cable. Test the battery
Old Aug 22, 2021 | 03:49 AM
No Quarter's Avatar
Maybe hit solenoid gently with hammer if long time since last time. Preferably while it's trying to engage
racerxf12004
E type ( XK-E )
Sep 26, 2021 06:20 PM
cityboy
Apr 27, 2021 11:11 AM
Uno Strzelichowski
Mar 22, 2019 12:22 PM
dinerdash
May 15, 2013 07:30 PM
maikal_0011
Nov 5, 2011 11:18 AM
