Power steering pump fluid change, ‘09 XK...do it yourself?
Old Sep 24, 2023 | 08:47 AM
ram_g's Avatar
That is analogous to needing to run way more brake fluid through a system (using a power bleeder, and compared to the system capacity) to achieve a full replacement of the brake fluid. There is no way the power steering system capacity is 4l because the flush instructions tell you to run 4l through the system. It's probably 3-4x the capacity of the system.
Old Sep 24, 2023 | 08:50 AM
ram_g's Avatar
According to ChatGPT...
what is the typical fluid capacity of a car power steering system
ChatGPT
The typical fluid capacity of a car's power steering system can vary depending on the make and model of the vehicle. However, in most passenger cars and light trucks, the power steering system typically holds between 1 and 1.5 quarts (approximately 0.95 to 1.4 liters) of power steering fluid. This is a general range, and some vehicles may have slightly larger or smaller capacities.
It's important to check your vehicle's owner's manual or consult with a qualified mechanic to determine the exact fluid capacity for your specific make and model. Overfilling or underfilling the power steering system can affect its performance and potentially cause damage, so it's essential to use the correct amount of fluid.
Old Sep 24, 2023 | 08:56 AM
justinhill's Avatar
I'm here to learn.
How much fluid do you estimate the pump, cooler matrix and hoses hold?
Old Sep 24, 2023 | 09:07 AM
ram_g's Avatar
Originally Posted by justinhill
I'm here to learn.
Well, as stated, the total capacity seems to be of the order of 1 liter. The pump holds hardly anything. The cooler is not really a matrix, more like a straight piece of tubing. The biggest "reservoirs" are probably the fluid tank and the steering rack itself. I have no reason to suspect that the total capacity is off by that much.
Old Sep 24, 2023 | 02:24 PM
ram_g's Avatar
Not a Jaguar at all, but here’s a similar back-and-forth about fluid capacity vs volume recommended for a flush:
https://mbworld.org/forums/e-class-w...w211-e320.html
Old Sep 25, 2023 | 07:36 AM
V7Sport's Avatar
From the Vehicle Specs document (09/2009), power steering fluid capacity about 1 liter/quart. See attached.
jomo
Aug 29, 2021 02:18 PM
yachtmanbuttson
Sep 10, 2020 11:33 PM
Johnken
May 29, 2018 11:39 AM
Dell Gailey
Jul 2, 2017 10:06 PM
ianw48
Feb 15, 2016 04:19 AM
