Question about engine mount part numbers
Old Nov 29, 2024 | 07:50 AM
Pat63's Avatar
Default Jaguar xk 4.2 2007 engine mounts c2p20052 and c2d2745
HI I also have an XK 4.2 Coupe year 2007 and wanted to confirm that i can use engine mounts C2D2745/ 8W83-6A003-BA/C2Z6265/C2Z5066/C2P17845/C2Z5066 which all seems to be compatible with 6W83 6A003AE or C2P20052?
Thank you,
Pat.
Old Aug 27, 2025 | 09:34 AM
Circumnavigator's Avatar
Thank you,
Pat.
Noting the 6W83-6A003-AE WER so nobody has to dig for it.
Part #s are above.
As I am about to do the engine and trans mounts, I’d love to keep it as cheap as possible, without a lot of risk.
Trans mounts are cheap, but the going rate new for 07-09 x150 jag part engine mounts are over $300.
No Bueno for a part that used to be 80-90 bucks.
I read 3 other threads on this (and whatever was linked within the thread), most quite old. And none with full resolution.
There are some used mounts on eBay around $125 for a pair. That can be a last resort. Used is used and by the time the Indie inspects them, I’ve eaten the cost.
Has anyone done mounts recently? (18mos or so)
I know you guys are a bunch of tightwads, like me, so if there is a cheaper solution, I’m confident you’ve found it.
Edit: Quick addition after a bit of searching.
https://ibspot.com/us/products/pango...rmarket-parts/
Lists other models but looks right, and i can knock out both engine and a trans mount in one shot.
Old Aug 27, 2025 | 11:07 AM
xalty's Avatar
motor mounts have been the same form since the first s-types rolled off the line. they’re all pretty much interchangeable
TropicCat
May 10, 2021 05:55 AM
Unclereggie
Feb 24, 2020 08:08 PM
Britrover
Mar 10, 2016 10:49 PM
FastKat
Jun 23, 2012 08:06 AM
Stu 1986
Dec 19, 2010 10:17 AM
