Radiator test?
Old Oct 7, 2016 | 07:41 AM
robbing's Avatar
Default Radiator test?
07xk
Is there a way to test a radiator once it's off the car, for a leak? I was told by a shop that mine was leaking at the neck of the upper hose. You could a small amount of coolant gunk but as most of you know you can't see that area very well. Yesterday I pulled the radiator and thought I would see a build up of coolant but I didn't. Wouldn't there be a build up of coolant where the hairline crack was? If not, is there a way to test it without it being on the car?
Old Oct 7, 2016 | 08:00 AM
jagtoes's Avatar
A radiator shop should have the equipment to pressure test a radiator out of the car and they should be able to SHOW you the leak. If they can't then you need to find another shop.
Old Oct 7, 2016 | 09:32 AM
shemp's Avatar
I know there are some places in East Plano (namely Bill's Radiator shop) but I wonder if generic repair place like City Garage or something like that would do it.
Old Oct 7, 2016 | 09:59 AM
robbing's Avatar
Shemp, Bill's is where I took it. Right when I walked into the back the guy said "yep it's bad." Besides it leaking there is also signs of rust so he said I need to flush my system. This will be my first time to flush an coolant system but since I have the radiator off I'm figure it will be easy. If anyone has good hints on doing that let me know.
Old Oct 7, 2016 | 12:29 PM
JackJohn's Avatar
Rob, this guy must have x-ray eyes. I would ask them to pressurize the radiator and show me the leaks. Then discuss cost of repairs.
XK_SL
Jan 31, 2024 07:55 PM
Supercharged Jag
Sep 20, 2016 09:40 PM
cadmat
Sep 17, 2016 04:02 AM
Bavery767
Sep 16, 2016 07:54 PM
Rjscharer
Sep 16, 2016 10:06 AM
