Reverse camera, iPod & USB added to 2008 XKR
#102
This is the one I bought;
https://smile.amazon.com/gp/product/...?ie=UTF8&psc=1
One must ensure that they get a camera in the correct orientation, so it has the correct view when the camera is mounted. Install the camera above either sticking "out" or up" and the picture will be upside-down.
I'm happy with my choice, it mounted well and looks almost OEM.
#103
I installed this one into an OEM plinth/finisher.
but I would use one similar to what CeeJay used if I was mounted to existing plinth.
Also you will need a brown Fakra cable similar to this one that will plug into back of screen. You will cut off other end to hardwire your camera cable to it... read thru the threads and you will find all the answers you need to get camera installed in your car. After that I will help you with the programming.
https://m.ebay.com/itm/Car-Antenna-E...8AAOSwTyJakR5f
here is the add a circuit I used for camera power or you can hardwire in if you choose.
#104
#105
https://www.amazon.com/gp/aw/d/B076V94KVY?psc=1&ref=yo_pop_mb_pd_title
https://www.amazon.com/dp/B06XPH1GW3...detail_2?psc=1
#106
Clellandm (10-22-2020)
#107
#108
Received 2,052 Likes
Cee Jay (06-11-2018)
#109
I liked that the OEM plinth didn't have JAGUAR written out on it and was painted body color, also I liked that the one I bought had the new trunk release button and OEM led lights with it, but most importantly it was available to me for a great price (Bought used from forum member). OEM camera is offset as well...
#110
#111
Another American on this thread
Hello everyone, I am in Cincinnati, adding a backup cam to my 2010 XKR convertible. In the process of acquiring a Fakra cable, camera and add-a-circuit to do the hardware part of this job. I have already unlocked various mysteries of IDS/SDD trying to chase out a radio problem on my car so I am fairly sure I can get the software part done when the hardware is in. I have a dedicated laptop I use with the car so maybe I can help others with the software part too once I am done.
#112
Do you have the 'special' files to do this? Maybe you should check... See if "Without parking assist camera" is greyed-out. If it IS greyed-out, then you need a bit of help yet.
#113
So curious, I know the process for installing/ activating a camera for the 07-09 models. The 2010 is easier, with simply installing the camera and activating it with enhanced software. Is the enhanced software that's required for the 2010 also needed for every year after? 2011, 12, 13, 14, 15? Anyone know?
#114
Sean W (08-21-2018)
#115
#117
For anyone interested in adding reverse camera, here is an oem finisher with camera mount...
https://www.ebay.com/itm/JAGUAR-XK-2...MAAOSwhhFbfn-6
#118
#119
Parts for a TV addition
I probably have several of the parts you need. I bought parts to multiplex Backup camera output into the Nav system output but then realized I can use a software change and have a backup camera like a 2012 and later car, so I have parts to sell now. Such as a NAV TV etc.
#120
I tried posting a link. In facebook, Old Jaguar - Australia
