Simple TPMS question
The cost to replace all 4 is about $200. The Jag XK/XKR will read the new TPMS and automatically reset after 5 to 10 minutes of driving.
I went thru the same problem on my 2009 XKR and after many frustrating months of warnings, replacing the 4 sensors fixed the problem immediately.
Thanks in advance,
Dave
Originally Posted by Someb
I had the same problem. The dealer installed an upgrade of the TPMS-software/system; so far so good.
Grtz
Ben
Grtz
Ben
I replaced them last season. I bought them off Amazon, they charged me $10 per tire to install them. They showed me the serial numbers from their reader. Matched my paperwork. What am I missing?
My bad. Disregard.
Sean W (04-20-2018)
#28
#30
#31
2007 xkr and I just had all four tires replaced and now the TPMS fault flitters around and then disappears. I had the sensors 'checked' before I did the tires and the diagnostic tool said the batteries were good. I've tried the 40+ pounds of air trick, I took out the tpms fuse and danced about the car, I may try nitrogen. But the deal is the sensors send out a fairly complex digital signal (at 315mhz) that has the pressure and lots of data encoded in it. So either the batteries are strong enough to send this signal or they aren't. And if the car can't see all four sensors and read the signal you get a 'sensor' error on the dash not a low tire warning. So if you don't see the sensor warning on the dash your sensor batteries are fine.
According to Jaguar of Tacoma it's the TPMS module in the trunk. A re-flash may fix it, but probably it needs replaced. And it's just a dang-odd thing it acted up RIGHT AFTER I had four tires put on.
#32
#33
Received 1,894 Likes
#34
End the frustration. Replace the TPMS. Your Jaguar XK/XKR is a 2007 and probably produced in 2006. Look at the door panel, it will provide a date of manufacturer. The TPMS has built-in non-replaceable batteries that last 7-9 years.
The life of your sensors are nearing their end of battery life.
Once a TPMS goes bad, the battery is not replaceable and the entire sensor needs to be replaced.
You will spend more time trying to diagnose the problem with lots of frustration in between. Your car is a 2007, probably built in 2006. (Look at the door panel for date of build).
Bite the bullet -----REPLACE all sensors. Buy the good ones ---SIEMENS.
__________________
#35
#36
Stuart:
I am looking. The aftermarket for the Jaguar brand is virtually non-existent. I am seeing 2014 XKR's for sale with ultra low mileage in the 25M range, which is unbelievable to me. There is just a very poor aftermarket for the brand.
I have read where Jaguar sales are extremely poor, especially in the sedans XF, XE etc.
#37
Yes, it's a buyer's market - and that's great if you're a buyer! Demographics have changed, and practicality rules. SUVs are King, and sedans are a dying breed. Cars like the XK are non-essential playthings for those who already have an SUV. Also, depending on where you live, intimidation by political correctness is a factor - witness the growth of EVs.
#38
Hey, richzak is back!
TMPS.... On my 2010, it seems whenever one or more of the tires gets low, the whole system goes bonkers. I went thru this last year (documented in a thread somewhere...), did the 40lb trick for 1 week and it worked. Ok now for about a year. Just recently I had a screw removed in a tire and whatever the tire place did triggered the Christmas light show. All tires were at 33lbs. I raised the pressure to 35 this time and it's fine again. For now.
I assume my TMPS transmitters are at the end of life but struggling to hang on. I'm hoping they will last until the next tire change (1-2 years). If not, I'll get them replaced like richzak recommends because that TMPS warning on the message center (the car graphic, not just the yellow triangle) is annoying.
So, to rickkym, If you can, drive around for a week or so with the tire pressure at 35-40 (you said you tried the 40lbs trick but didn't say for how long) . See what happens. Maybe the system will settle. If so, drop back down to 33lbs. If it doesn't fix it, no harm done.
#39
shemp (01-22-2019)
#40
__________________
