Thank you to the forum!
Old Jul 12, 2025 | 09:03 AM
DlsXK's Avatar
Default Thank you to the forum!
Just wanted to shout out to all the experts here for all your help over the years. 6 years ago I bought a pretty rough XK convertible. Price was great, but it needed some work. Over that time, with a ton of forum help, I did the following:
re glued rear window (has held for 6 years)!
replaced drivers door trim
replaced broken tweeters/trim
replaced coolant reservoir (mystery leak that only sprayed when car was being driven!)
replaced evaporator can
replaced mirrors on visirs
overhauled and refurbished headlamps
replaced seat belt buckles
rear sway bar bushings
new trans fluid and pan/filter
overhaul air intake, maf sensor
replaced coolant overflow hose (recent help with part number - thank you)!
3 stage paint correction. Clapped out ebony paint now ahead turner!
thank you again to everyone in the forum. Could not have done all these things without y’all.
now I just need to get the secondary air intake to show “ready” mode. Have a bunch of ice bags under car to try to trick it into thinking it’s cold outside, but it’s just too hot here.
Throwback
Jul 17, 2022 08:01 PM
ASpicy1
Apr 5, 2020 06:51 AM
Ipc838
May 11, 2012 04:22 PM
blaqjag
Dec 15, 2008 01:39 AM
