tire propellant?
Old Jul 9, 2015 | 09:58 PM
RedRider48's Avatar
Default tire propellant?
Hey Guys,
As an owner of a Jag that only has the emergency inflator pack, what's a body to do? The propellant expired a couple years ago and I'm starting to feel mortal. LOL!
I know I can search for the XJ Supersport spare tire kit etc, but, I really like the extra room that vacant hole offers. Have also learned, once the propellant is used, the tire may be permanently damaged, as well.
So, what are the rest of yous guys doing?
A followup question.... Can the Jag inflator be used without's it's propellant pack?
Old Jul 9, 2015 | 10:25 PM
NBCat's Avatar
Pulling up in our 250 GTE to lend a hand to a pretty woman from Rome?
Old Jul 9, 2015 | 11:38 PM
plums's Avatar
Will generic tire sealer cans not work?
Old Jul 10, 2015 | 05:16 AM
Ngarara's Avatar
You can use the inflator without the gunk - I did it a while back when I discovered a flat. I'd always try to reinflate the tyre before filling it with crap, because there's always the possibility that it's a slow leak (which turned out to be the case).
There are other sealer products, including some that are water-based and don't cause any issues if they are left in the tyre and can be washed out if the tyre is deemed repairable. But I'm not sure if they can be plugged into the Jag inflator. It's possible you'd have to squirt the gunk in separately, and then use the inflator.
Old Jul 10, 2015 | 08:33 AM
RedRider48's Avatar
So, is it possible to use the Jag inflator without the gunk that comes with it?
Now that I've re-visited this, I'm thinking along the lines of what White XKR mentioned...., obtain an inflator and a DIY tire repair kit. But then, you have to plan on the puncture to be visible, else, the tire needs to be rotated in some way to expose the offending nail, screw etc.
I like there is a more friendly sealant that won't render the tire useless. I'd hate to replace a $300 new tire due to a simple nail.
Old Jul 10, 2015 | 08:43 AM
Originally Posted by Ngarara
You can use the inflator without the gunk - I did it a while back when I discovered a flat. I'd always try to reinflate the tyre before filling it with crap, because there's always the possibility that it's a slow leak (which turned out to be the case). ...........
If that useful information isn't prominently displayed on the inflator pack instructions than it most certainly should be.
Old Jul 10, 2015 | 09:06 AM
jagtoes's Avatar
Not having the inflator pack would someone please post a picture and show how it's used. I assumed it was just a can of the spare tire in a can .
Old Jul 10, 2015 | 09:50 AM
RedRider48's Avatar
It's called a ContiMobility Kit...has not one shred of "written instructions", simply pics of the steps.
Attached Thumbnails tire propellant?-img_0376.jpg   tire propellant?-img_0377.jpg   tire propellant?-img_0378.jpg
Old Jul 10, 2015 | 10:48 AM
RedRider48's Avatar
While we're beating this up, anyone used the sealant when it was beyond the expiration date?
Old Jul 10, 2015 | 12:03 PM
Ngarara's Avatar
Mine looks different to the one RedRider has - it's a black plastic box with the hoses & cables stowed inside it. The instructions are in the user manual, though I think there are some inside the box too.
Never used the gunk, not sure if mine is in date or not (must check).
Old Jul 10, 2015 | 02:57 PM
andys-GR's Avatar
I always carry a can of 'fix a flat' it works great, yes tire places don't like it since they have to clean up the mess. I started carrying it in my old Carrera 4 as there wasn't much trunk space with the space save and the rear wheels would only fit in the passenger seat so if I had company something was being left on the side of the road!
I was thinking earlier today of removing the space saver for the extra space, so my vote is ditch the donut.
Old Jul 10, 2015 | 10:59 PM
Stuart S's Avatar
Andy,
Don't simply ditch the donut; replace it with a Bible so you can pray that you never get a non-repairable flat! Why Jaguar didn't fit runflats to models without a spare is beyond me.
Stuart
Last edited by Stuart S; Jul 10, 2015 at 11:16 PM. Reason: Deleted unwanted link to a tire website. No idea how it got in here.
Old Jul 10, 2015 | 11:01 PM
Stuart S's Avatar
Delete
Last edited by Stuart S; Jul 10, 2015 at 11:13 PM. Reason: Inadvertent duplicate post
Old Jul 10, 2015 | 11:11 PM
Stuart S's Avatar
Ken,
My 2009 XKR Portfolio came with the same kit as your 2008 XKR Portfolio since both our cars have Alcon brakes. I was concerned about getting stranded with a non-repairable flat, so I added a compact spare. For details, see: https://www.jaguarforums.com/forum/x...-brakes-67260/
Stuart
Old Jul 11, 2015 | 06:39 AM
RedRider48's Avatar
Yes, Stuart S, ........
one of the dumbest engineering blunders, including, no gauges and no dip sticks, and a twitchy electrical system, as well.
Old Jul 11, 2015 | 11:37 AM
andys-GR's Avatar
My luck is if I get a repairable flat the car will be full and I'll have no place for the rim and flat tire !!
Old Jul 13, 2015 | 02:42 PM
richzak's Avatar
I bought the spare donut tire for my 2009 XKR portfolio edition. I also carry a DynaPlug Tire repair kit as a backup if needed. Easy to use.
In fact none of my premium sports cars have a spare tire except the XKR now. I bought a small 12v air compressor to carry along with the tire plugger. I never have any worries.
Amazon.com: Dynaplug Ultralite Tubeless Tire Repair Tool Kit, Made in USA: Automotive Amazon.com: Dynaplug Ultralite Tubeless Tire Repair Tool Kit, Made in USA: Automotive
Amazon.com: NEW Portable Mini Air Compressor Electric Tire Infaltor Pump 12 Volt Car 12V PSI: Home Improvement Amazon.com: NEW Portable Mini Air Compressor Electric Tire Infaltor Pump 12 Volt Car 12V PSI: Home Improvement
With these accessories, I should be able to make it home or to a tire repair sho[p.
Old Jul 13, 2015 | 03:05 PM
RedRider48's Avatar
I have those things on order. But, wondering how good having them, if I can't get at or see the offending nail. Would need a mini-jack of some type to raise the axel.
Old Jul 13, 2015 | 10:17 PM
richzak's Avatar
You can probably find a used Jaguar jacking kit on eBay. That is what I did and paid about $40.00.
Old Jul 13, 2015 | 10:23 PM
RedRider48's Avatar
Hmmm, good idea. Had thought about a bladder style and inflate it with the external tire pump I ordered, that is, if I don't kill the battery LOL!
What years will the jacks cover?
