U.S. based parts suppliers
Old Mar 8, 2023 | 02:57 PM
KJsJag's Avatar
Default U.S. based parts suppliers
Hey guys,
So who have you had good experience with in US based parts suppliers for these modern Jags, beyond the dealer? Hoping for something like Pelican Parts, but that offers Jag branded, OEM non branded, and third party options and is pretty comprehensive in what they carry. Does such a place exist? Who do you use?
Old Mar 8, 2023 | 10:39 PM
ralphwg's Avatar
Try SNG Barratt: https://r.search.yahoo.com/_ylt=Awr9...KVAW9QrkBtIEY-
Old Mar 8, 2023 | 11:28 PM
Stuart S's Avatar
for OEM Jaguar parts.
For aftermarket parts, try RockAuto.com
https://www.rockauto.com/
Your question is too broad. No single source has everything. What kind of parts are you looking for? Body parts? Interior trim parts? Engine parts like fuel injectors or filters? Electronic modules? TPMS sensors? Maintenance items like brake pads and rotors? Some parts are no longer available from the factory, and many parts were never available from the aftermarket.
Below are the original parts suppliers for the Jaguar X150 when the Ford Premier Automotive Group owned Jaguar, Land Rover, Aston Martin, and Volvo. Many Ford parts were used in those brands.
https://en.m.wikipedia.org/wiki/Prem...tomotive_Group
Old Mar 9, 2023 | 09:09 AM
KJsJag's Avatar
Thanks for the reply's. I did find SNG after posting since they are a sponsor.. Doh. The only parts I need at the moment are TPMS module/receiver possibly, and rubber replacement boots for the rear suspension that don't appear available any more. There just seems to be far fewer options then I had for my '06 Boxster S. I guess that's understandable as these seem to be a far more rare car. I just know the outrageous markup OEM branded parts generally have and was able to save quite a bit of money on Porsche parts built by the same OEM supplier just not branded Porsche. I guess it will just be a bit more of an adventure should future (hopefully not many) items be needed. I've never looked at Rock Auto, so thanks for that as well.
Old Mar 9, 2023 | 09:19 AM
panthera999's Avatar
Originally Posted by KJsJag
Hey guys,
To find true OEM, or name-brand near-OEM, takes some searching and detective work. Some of the big ones I've been able to find are
Bilstein for dampers (CATS are getting hard to find, but if you disable it, plenty of product out there).
Lemfoerder for suspension parts (getting hard to find: Eurospare, non-OEM, seems to be working in the niche),
Denso for 4.2 ignition, emissions, some electronics and AC;
Bosch for 5.0 ignition and injectors (I think -- not my space); not sure who does 5.0 AC;
Brake rotors and ceramic pads are available from Zimmerman and Akebono, et al.
best Oil, Air Filters from Mann and Mahle. Avoid US oil filters or any cheap alternative. Some have documented experiences with filter crush under pressure.
If you can find them, Ford part numbers may find alternatives that Jag part numbers don't. Like a Jag $700 suspension part for $150 from Ford. harder to find as time passes.
Some parts are also used on Land Rover, and can be matched at a reasonable price due to LR's relative popularity vs jag.
The point is you have to search. But, real OEM can be found for 50% or less than Jag parts. JLR prices are absurd.
Some are really hard to find, like 4.2 injectors at a reasonable price.
Good luck.
mlrtime99
Nov 20, 2021 01:17 PM
kbeachy
Dec 22, 2014 11:12 AM
Bodyman
Mar 20, 2011 06:26 PM
goldencharriot
Sep 15, 2009 11:41 AM
