Water drop on my feet when I turn right!
Old Aug 16, 2019 | 08:05 PM
Quebecjag's Avatar
Default Water drop on my feet when I turn right!
I’ve been surprise when I received some water on my feet this afternoon.
didn’t drive in rain lately, just wash the car a few days ago. Drive about 1000 miles in the last week in vacation. Good weather, not particularly humid.
any ideas what can produce that?
guy
Old Aug 19, 2019 | 11:29 AM
110reef's Avatar
Search this forum for duckbill
Old Aug 19, 2019 | 03:56 PM
jagtoes's Avatar
Stop turning right and the problem will go away. (sorry , just had to say it)
Old Aug 19, 2019 | 04:06 PM
Brutal's Avatar
Ac drain i plugged
Old Aug 23, 2019 | 04:58 AM
Ngarara's Avatar
More complete answer: there is a small rubber drain tube for the air conditioning that sticks out from the firewall into the engine bay, just above the transmission. it is known as the "duckbill" because of its shape, which is designed to allow water out but prevent insects getting in. It becomes blocked because the two halves of the bill become stuck together, especially in hot, dry conditions. That means water builds up in the a/c system and drips out, usually into the passenger footwell - it can even short out the blower motor.
The first thing to try is to close all the a/c vents and tape up the ones in the footwells, then turn the fan on full blast - the pressure this creates may blow the duckbill open. If that doesn't work, the only fix is to modify or replace the duckbill. There are two ways: the easy but expensive way is to remove the whole dashboard to get at the tube from the inside. The hard but cheap way is to use a borescope or a mirror on a stick to find the duckbill, and then a sharp blade on a stick to cut most of it off - this not a simple job.
Old Aug 23, 2019 | 06:27 AM
Stuart S's Avatar
No need to tape the ducts in the footwell if you manually adjust the vents to face only.
Old Aug 23, 2019 | 08:12 AM
Ngarara's Avatar
Ah, OK, so set the system to face-vents-only using the touch screen, then close them?
Old Aug 23, 2019 | 09:46 AM
Canadacat's Avatar
Boots, wear boots.
Old Aug 23, 2019 | 11:15 AM
Quebecjag's Avatar
Default Well!
Thank you all for the info.
not a unique problem. The tread on that topic as 12 pages!
I’ve drive another 1000 miles since the weather flood but it seem it was a single event. But I will try to blow it anyway.
I think I will blow in the vent with my leaf blower to increase the pressure. Will see.
Guy
Old Aug 23, 2019 | 12:53 PM
Stuart S's Avatar
Yes, and vary the air speed occasionally between FULL BLAST and s l o w to hopefully force the condensate out of the duckbill.
Old Aug 23, 2019 | 04:45 PM
u102768's Avatar
I am surprised that the OP has a wet foot issue as his car is a 2012. The duckbill with the wider opening was introduced a couple of years before that.
Old Aug 24, 2019 | 05:03 PM
Ngarara's Avatar
Ah, good point - though I think I saw a couple of posts that said it happened on 5.0 cars. It's certainly not frequent, unlike 4.2s. The later tube has a very short bill, but there's still a flattened section that clamps together and I guess it's possible for it to get gummed shut.
Old Aug 24, 2019 | 05:05 PM
Ngarara's Avatar
As u102768 has pointed out, the duckbill issue is usually only on 4.2 cars, though it's not impossible on a 5.0. And it usually drips into the passenger's footwell, not the driver's. Maybe you have a different problem.
Old Aug 24, 2019 | 08:22 PM
u102768's Avatar
It does but the duck bill was changed from VIN B34500 which is partway through the 2010MY.
WAFlowers
Jul 16, 2021 10:38 PM
XKJoe
Jan 25, 2016 04:49 AM
Wolfy
Jul 24, 2015 04:26 PM
John P.
Aug 30, 2011 03:04 PM
dbrojr
XJ40 ( XJ81 )
Aug 12, 2011 05:06 AM
