Gear selector fails to elevate HELP
Old Today | 08:44 AM
RHiza's Avatar
Angry Gear selector fails to elevate HELP
My 2013 XKR starts and runs for about 20 seconds. Shows no RPMs. Message: Fuel Low. Tank was filled day before. Gear selector fails to elevate.
HELP!!!!
Ron
Old Today | 10:22 AM
Cee Jay's Avatar
First thing to do nearly EVERY time you encounter a problem.......... Check the battery voltage (HAS to be 12.6 volts after sitting overnight) and do a Hard Reset by touching the disconnected battery cables together for several seconds while avoiding any contact with the battery itself. This resets all the volatile memory in all the modules and may very well cure the problem. It costs zero dollars and takes maybe ten minutes. No sense in doing anything else until this is tried first.
Old Today | 11:43 AM
RHiza's Avatar
HELLO Cee Jay:
Thank you for your response. I did do what you suggested before and no fix. I should have reported that the car started when I backed out of the garage and shut it off. About 10 minutes later, the problem started.
Old Today | 12:42 PM
Cee Jay's Avatar
So what is the resting battery voltage?
Old Today | 01:54 PM
RHiza's Avatar
jaggy1948
Today 01:04 PM
bjg625
Jul 22, 2019 10:13 PM
Rogelio Serrano
Dec 4, 2016 10:50 AM
Moe-she-sa
Dec 21, 2011 08:52 PM
Currently Active Users Viewing This Thread: 3 (1 members and 2 guests)
