So I been having the searching for satellite error, and used the ICarsoft I930 scanner to read the codes..the code shows antenna error. so I purchased an ebay one and replaced the antenna ,with the same effect..but when my trunk is in the open position, I can get a clean satellite signal, when closed no dice....so I did check all wiring but still have the error..has anybody seen this before??
thanks
al
thanks
al
