Where does my ground cable go?
Old Oct 31, 2016 | 04:52 AM
1 of 19's Avatar
Default Where does my ground cable go?
Yep I did look but wasn't going to take off insides to verify. Our cars are aluminum so does my battery ground cable attach to the body as in a steel bodied car or is it a loop? Can aluminum be used as ground?
Old Oct 31, 2016 | 05:22 AM
jimbov8's Avatar
Have a look under the left side panel in the trunk and you will see it is to the body.
Old Oct 31, 2016 | 08:46 AM
WhiteXKR's Avatar
As long as the factory provided ground studs are used, the aluminum body is a proper ground.
I am sure the ground stud material and staking process is carefully engineered, because using aluminum oxides can form ruining the connection if it is not designed properly.
