Wipers and Washer Pump stuck! Need fuses for both!
Old Sep 15, 2019 | 07:56 AM
virtual_law's Avatar
Default Wipers and Washer Pump stuck! Need fuses for both!
Greetings catowners!
First post here! Apologies if I come off a noob!
I got a 2009 Jaguar XK standard that was fine up until two days ago. Came home after a drive and Wipers and Windshield Pump came on and wouldn't power down. Switch is useless. Have disconnected the battery since.
I have pulled the fuse under the hood F26 and F4. Now when I reconnect battery, wiper motor doesn't power on but I can hear the Windscreen Washer Pump's constant whirring! Please point me to the right fuses to pull in Passenger Footwell Fuse Box. Can't find a diagram anywhere.
P.S I do NOT have the owners manual sadly.
Thanks a lot!
Old Sep 15, 2019 | 12:30 PM
arenaej's Avatar
Here ya go!
File Type: pdf
Old Sep 15, 2019 | 12:48 PM
Thank you so much!
Old Sep 15, 2019 | 01:59 PM
ralphwg's Avatar
You can also download the owner's manual. Just look up in the stickies and you will find a link to the manual. Good luck in solving your issue.
Old Sep 15, 2019 | 02:10 PM
Originally Posted by arenaej
Here ya go!
I might need a bit more help.
I've pulled both F4 (powerwash pump) and f26 (wiper motor).
But I can still hear the powerwash pump (I'm guessing) whirring from near the Driver side fender as soon as I reconnect the battery.
Can someone please guide as to what fuse is needed to be pulled to stop this from happening or any other way to disconnect windscreen water pump?
Edit: Video of issue here:
https://youtu.be/Cq_d2gg4Oi8
Thank you!
Old Sep 15, 2019 | 03:51 PM
Cee Jay's Avatar
You can HEAR the pump? Is there fluid coming out the nozzles? Is there fluid in the reservoir?
Are you sure that it is the washer pump and not some other noise?
Also, do a Hard Reset, that'll clear up most electrical gremlins, along with a FULLY CHARGED battery.
gordyshreds
Jun 3, 2021 07:31 AM
Dav2ison
Apr 9, 2019 07:27 AM
Rex
Jun 1, 2018 10:15 AM
95 Cat
Oct 21, 2016 09:37 AM
Gareth Reaper Pollard
May 3, 2013 06:41 AM
