XKR vs XJR: 420 vs 400 hp??
Old Sep 26, 2020 | 10:27 AM
hisport's Avatar
Default XKR vs XJR: 420 vs 400 hp??
I'm doing the infamous Valley Hose on my '07 XJR. Also, servicing the (M112) SC and other stuff along the way. And, got to wondering: where did that extra ('07 - '09 4.2L XKR) 20 HP come from?
(My thought is dual air filter intake system; maybe freer exhaust as well?)
...still looking for a pristine XKR coupe...
Old Sep 26, 2020 | 02:55 PM
MarkyUK's Avatar
weight perhaps 4k lbs vs 3.7k?
Old Sep 26, 2020 | 03:50 PM
jahummer's Avatar
Ummmm, weight would affect acceleration, not horsepower....
Various small tweaks including larger crank pulley, dual intakes and VVT VCT AJ33S vs. AJ34S
Old Sep 26, 2020 | 08:46 PM
hisport's Avatar
Thanks JA
The SC XJ models X356 (late '06 - '07 in USA) and X358 ('08 - '09 USA) do use the 400HP VVT SC engine (AJ34S, I believe). Earlier X350's use the 390HP AJ33S
Didn't realize the early XKR's use more SC overdrive (larger crank pulley). Imagine they need LSD even more than the XJR does. I see you added this to your '08...
Appreciate the info!
rscultho
Sep 28, 2020 11:11 AM
ds1058
Jan 9, 2013 09:29 AM
Drew
Sep 16, 2010 10:24 AM
