Your opinion please
Old Sep 6, 2017 | 09:50 AM
chiefmd's Avatar
Default Your opinion please
New to the forum. Came across a 2012 XK two owner with 16895 miles. Owner is asking $31000. No accidents. First owner was a elderly lady and he is 62. The carfax shows no issue. What you opinion? Thanks for your input - Mike
Also has a USAA Warrenty I believe 5 years or 75000 miles from April 2016
Old Sep 6, 2017 | 10:01 AM
shemp's Avatar
Sounds good so far Any other info on it? Coupe? Convertible? Color?
KBB shows a 2012 XK coupe at $34,000 from a private party so the price seems correct. A lot here recommend a private inspection be done so you know exactly what you are getting in to. I think the cost is a few hundred and any Jag dealer should be able to do it.
Old Sep 6, 2017 | 10:17 AM
chiefmd's Avatar
Yes. Coupe, Lunar grey metallic, trim code SEP I believe its called caramel
Old Sep 6, 2017 | 12:01 PM
chiefmd's Avatar
Called the Jaguar dealer and they quoted $300.
Old Sep 6, 2017 | 12:17 PM
shemp's Avatar
Do it before you drive it because once you drive it you're gonna want to buy it
Good luck and keep us posted!
Old Sep 6, 2017 | 09:27 PM
ralphwg's Avatar
Also have a Jaguar approved body shop check out the Body for anything that might be awry. that should cost no more than addition $300 and maybe less. If you do the PPI the dealer will probably supply you with a list of items may need further checking/work. As far as I know the USAA warranty is transferable; if you don't know that as a fact ask to read it before you buy the car and pay particular attention to the exclusions. Oh, and good luck! Shemp is right on have the inspections done before you drive it, otherwise you will be hooked no matter what.
