acceleration problem
car xk140 rhd 1956 1 3/4" carbs will start run stationair, choke switches off, keeps running nicely but when accelerating the engine stays idle and does not pick up a higher rpm, when i lift the pisons manually it will increase in rpm. (fuel pump issue, low pressure, pistons and suction chamber failure....) please help
Tommy Ferrugia
Oct 11, 2016 12:13 AM
mJohn337
Oct 4, 2016 02:43 AM
