XK120 XK140 XK150 1948 - 1962
XK 150 Help
Old Apr 14, 2015 | 06:48 PM
rockingchairmotors's Avatar
Default XK 150 Help
I need some help identifying a XK 150. I am not too familiar with the 150.
I think it is a plan 150 or is it an S?
chassis # S834250
Engine # V 1328-8
Thanks for the help
Old Apr 15, 2015 | 08:06 AM
Jagfixer's Avatar
An S model 150 would usually have an S on the cowl designating the model. Is this a 3.4 litre or a 3.8 litre as there are different motors. Pictures would help. Does the car have any mods, such as fog lights, twin exhaust, etc.? Look carefully at the S in the serial # and confirm with car and title it is not a 5. My title here has the 5 transposed for an S.
Old Jul 25, 2015 | 04:49 PM
sailor's Avatar
I am not sure if you got this question resolved but here are a few points that I believe are correct.
The first 3.4L "S" OTS LHD with a chassis S prefix was produced on 24 April of 58 as S830336D/N. The factory went to a "T" prefix in Aug 58. the engine number should read VS1xxx-9 if it was an "S" engine.
Since yours is a V 1328-8 engine it is a standard 3.4L engine with 8 to 1 compression.
All 3.4L "S" engines had 9 to 1 compression ratio, triple HD8 carbs etc.
The early designation of prefix S stood for "Special Equipment" I am not sure exactly what that meant as far as the early XK150's. You may try entering your info on XKData.com. There are several experts out there.
PhilXJ6
Jan 3, 2016 08:55 PM
baskervillema
Oct 1, 2015 06:43 PM
kiddhan625
Sep 25, 2015 12:04 PM
John Fox
Sep 19, 2015 07:56 PM
PinnacleWax
Detailing / Car care
Sep 16, 2015 10:28 AM
