Two problems-PO171 and rear lights
Old Aug 13, 2013 | 04:18 PM
Sqeeter91's Avatar
Default Two problems-PO171 and rear lights
I have two separate problems. I'm getting a PO171 code. The second problem is a warning light saying Cruise not available/ Check rear lights. When we check the lights,they are all working. The cruise won't work when the warning lights are flashing. If we shut the car off and restart, all works fine, and warning lights are gone.
Old Aug 14, 2013 | 04:03 AM
JonWat's Avatar
DTC P0171
FAULT DESCRIPTION A bank combustion too lean
MONITORING CONDITIONS Engine at normal operating temperature
drive at steady speed > 40 mph;
engine speed 1300 – 4500 rpm
> 1 minute 20 seconds
Old Aug 14, 2013 | 07:53 AM
Sqeeter91's Avatar
What's the probable cause? O2 sensor? I understand the rear light thing is probably the brake switch
Old Aug 14, 2013 | 10:43 AM
oldmots's Avatar
P0171 causes:
- Intake air leaks
- Faulty front heated oxygen sensor
- Ignition misfiring
- Faulty fuel injectors
- Exhaust gas leaks
- Incorrect fuel pressure
- Lack of fuel
- Faulty Mass Air Flow (MAF) sensor
- Incorrect Positive Crankcase Ventilation (PCV) hose connection
Help with this
Read more: P0171 Jaguar System Too Lean Bank 1 OBDII Engine Light Trouble Code | Engine-Codes.com
Old Aug 14, 2013 | 08:19 PM
Gus's Avatar
Gus
With the cruise not available I would say to check the brake switch. Because you do not have P0174 with your P0171 I would say to check the 02 sensor
99xk8guy
Sep 29, 2025 10:51 PM
mbergen
Oct 23, 2019 10:26 PM
King Charles
Sep 3, 2015 12:40 AM
OkieTim
Sep 2, 2015 12:48 PM
innzane
Sep 2, 2015 10:08 AM
