01 stereo system ??
Old Oct 11, 2011 | 02:12 PM
randyb's Avatar
Default 01 stereo system ??
Trying to figure out my system, it does not have navigation, so does that mean I have the non-premium system?
Also, I have mike for for bluetooth, but I do not have a connector for the Motorola phone, does that mean whoever bought the car new, did not get the phone or did all 01's get the mike regardless?
I have 2ohm speakers in the rear, are they regular speakers or sub-woofers?
I have tried to research these questions, but I have seen conflicting answers.
Like one post says if you have an amp, you have the premium system (I have) and one post stating that the navigation system is the premium system and all stereos came with amps.
Old Oct 11, 2011 | 02:36 PM
renaultvation's Avatar
You should find all the answers you need here:
https://www.jaguarforums.com/forum/x...ertible-61487/
In short, yes you should have a premium system. It was standard equipment from 2000, but instead of an amp visible above the cd player, it is hidden behind the side trim in the boot (sorry trunk!).
Old Oct 11, 2011 | 02:49 PM
randyb's Avatar
Thanks, that answers my stereo question, now for double or nothing, do you have an answer for bluetooth question?
I might even go for triple, depending on your answer.
Old Oct 11, 2011 | 03:10 PM
Reverend Sam's Avatar
Why do you think you have a bluetooth mic? I took apart my header the other day and found a couple of microphone looking thingys behind that mesh screen up by the map lights. It turns out that they aren't microphones, though. They are ultrasonic sensors for the airbags. What does your mic look like, because maybe I have one, too, and I just don't know it.
Old Oct 11, 2011 | 04:53 PM
randyb's Avatar
Huh, it has a foam around it and it does sit about 3-4 inches from the mirror. But WHY would somebody put a sensor there????
It is black and hangs down about an inch and is below the sun visor, seems like a very dumb place to put a sensor.
2001 White XJ8
Feb 25, 2021 05:02 PM
mbergen
Oct 23, 2019 10:26 PM
adam699
Sep 12, 2015 05:32 PM
AL NZ
Sep 4, 2015 08:39 PM
