05 XK8 Antenna will not stay down
Old Sep 27, 2014 | 04:51 PM
05XK8's Avatar
Default 05 XK8 Antenna will not stay down
I have an 05 XK8 and the radio/antenna seems to work fine except the antenna will not stay in the retracted position as described in the manual when the radio is off and car is running. Place the ignition switch in position I or II and the antenna goes up. Shut the car down and the antenna goes down. Turn the car on and leave radio off or turn off and the antenna goes up/does not retract. Any idea what to look for?
Old Sep 27, 2014 | 05:45 PM
Stamford's Avatar
Is it possible the previous owner installed an auxiliary switch (perhaps in the console) for controlling the antenna and it's causing this behavior? Instead of preventing the antenna from rising, it's causing it to stay extended?
Old Sep 28, 2014 | 09:59 AM
05XK8's Avatar
From the documentation that came with the car, it is the stock Factory Alpine AM/FM/CD/Tape deck, which works great. I was thinking that there may be some kind of setting, but it doesn't say anything about it in the manual.
Old Sep 28, 2014 | 10:32 AM
Mountaincat's Avatar
Need to quit putting Viagra in the fuel tank.
Old Sep 28, 2014 | 12:10 PM
Chuck Schexnayder's Avatar
Open the console box and look in the rear of it for some kind of switch----as mentioned above--. It may have one and just changing the setting (on or off) may solve your problem.
Another possibility is your (music) CD player may not really be turning off. You say the radio turns off and on, so that should be OK. I can't remember if the ANT operates when the cassette is used, but you might check that. It may have one stuck in it.
Chuck
05/XK8 Conv.
99xk8guy
Sep 29, 2025 10:51 PM
99xk8guy
May 28, 2024 09:36 PM
2001 White XJ8
Feb 25, 2021 05:02 PM
perezal
Jan 3, 2016 08:59 AM
'05 Gold XJ8L VDP
Sep 18, 2015 07:15 AM
