05 XKR Supercharge removal, to do list while its off!
Old Sep 4, 2022 | 02:08 AM
LausDeMaus's Avatar
Default 05 XKR Supercharge removal, to do list while its off!
I am planning on removing the s/c to fix a leak with the valley hoses. Seeing as it's a big enough job, anyone any recommendations of other work to do while it is off? The car is coming up to 100k
Jack
Old Sep 4, 2022 | 08:14 AM
ccfulton's Avatar
Send the injectors off to have them cleaned and tested.
Spark plugs (don’t need the SC off for that but good to do at about 100k).
Thermostat (you have to take it all apart anyway).
Inspect and replace as needed intercooler hoses, SC outlet pipe seals.
Change SC oil and check bearings for play.
New SC belt.
Refresh coolant (you don’t get much choice on that one).
Good opportunity for an overdrive pulley if that’s your kind of thing.
Old Sep 4, 2022 | 11:19 AM
Kuddlesworth's Avatar
Make sure the intercooler pump actually works.
Old Sep 5, 2022 | 07:25 AM
crvols's Avatar
Default They just did this on Wheeler Dealers
Jack
I just watched the latest edition of "Wheeler Dealers" on TV and they serviced the supercharger on an S Type R. I believe this is the same unit? They had the rotors recoated with Teflon and a complete service kit installed. Might be informative if you can catch it on MotorTrend TV.
alexander thegreat
Aug 27, 2019 09:44 PM
