2000 XKR convertible - side door powerless
Old Feb 6, 2015 | 06:39 PM
steeley mcbeam's Avatar
Default 2000 XKR convertible - side door powerless
Hello Everyone, I need help. I have no power to driver side door. the fuse is good, what now? I'm a new member. had my car for three whole days now,I live in Williamsburg Va. also any recommendations for good local mechanics welcomed. Thanks Steeley Mc.
Old Feb 6, 2015 | 07:13 PM
Welcome to the forum steeley mcbeam,
I've moved your question from General Tech Help to XK8/XKR forum. Members here with the same model will be able to help.
Old Feb 6, 2015 | 10:29 PM
WhiteXKR's Avatar
Just as a double check, the fuse is number 15 in the fusebox on the driver's side of the dashboard. This car has 4 fuseboxes, so be sure you are looking in the correct one.
Also check the round connector that connects the door to the body: it should be fully turned clockwise.
Other causes could be a a broken wire in the door harness, which would most often happen in the cable between the door and the body, or failure of the Driver door module itself.
Old Feb 7, 2015 | 07:56 AM
white xkr. thank You ,low and behold it's working fine now.the door connector will be my next check. thanks again.so glad I joined this forum. I'll post a pic of my baby soon
MarathonJohn
Sep 3, 2015 07:59 PM
TC Johnson
Aug 29, 2015 08:55 PM
peterg19
Aug 28, 2015 08:42 AM
MrNobody
Aug 27, 2015 07:49 PM
divingmom
Aug 25, 2015 07:54 PM
