2001 xk8 4.0
Old Jan 13, 2017 | 02:43 PM
WJP's Avatar
WJP
Default 2001 xk8 4.0
DOM: 11/2000. 2001 XK8 convertable I believe I have second generation Timing Tension brackets. Is that correct and if so should I be thinking about replacing them? The car has 56,000 miles. WJP
Old Jan 13, 2017 | 02:56 PM
Welcome to the forum WJP,
Engines built after August 13th 2001 have second generation tensioners so your original plastic tensioners are on borrowed time.
Old Jan 13, 2017 | 03:19 PM
WJP's Avatar
WJP
Thank you for your response. Will take your advice
Old Jan 13, 2017 | 03:34 PM
WJP's Avatar
WJP
Should I replace the water pump and thermostat at the same time I replace the Tension brackets? From your experience, what is the ball park price for having a professional do the work?
Old Jan 13, 2017 | 07:34 PM
RJ237's Avatar
Yes to that and also the crossover pipe and radiator hoses. This could run $800 to $1500 easily just doing upper tensioners and plumbing.
If you are going to use professional services for what most of us consider DIY projects this could be a very expensive car to maintain.
Old Jan 14, 2017 | 02:34 AM
There's three regular issues with the XK8/XKR:
1.) plastic tensioners
2.) cooling system - water pump/thermostat tower/hoses
3.) so called 'sealed for life' transmission - a fluid change at around 70k miles extends life
Most buyers end up doing all the above and then enjoying troublefree driving.
