2001 XKR Fuel Pump Problem in Storage
Old May 27, 2019 | 12:22 PM
Dr. D's Avatar
EKKI:
If you have not already, I suggest pulling both relays and jumping in turn both primary and secondary relay receptacles for relay blades #3 and #5 while listening to hear if each pump is running. It is not necessary to turn the ignition on. I do this check routinely on a 6 month basis. It also gives the secondary pump a little exercise to prevent being pickled in gasoline.
Old May 27, 2019 | 01:33 PM
Ekki's Avatar
Thanks for your input, guys.
I have tinkered a bit in the meantime. This is the current 'status quo':
Both FP-relays installed - car won't start (cranks, tries to ignite but dies off almost instantly)
FP1 relay installed - same as above
FP2 relay installed - car starts immediately BUT restricted performance upon next start and code P1230 (probably refers to missig FP1 relay)
I switched relays, made no difference.
Old May 27, 2019 | 01:58 PM
Ekki's Avatar
Found this thread in the meantime -
https://www.jaguarforums.com/forum/x...-around-31160/
Problem seems likely to be the primary fuel pump.
Old May 28, 2019 | 04:29 PM
Ekki's Avatar
Thanks again for you help, guys - highly appreciated.
Since I have a Coupe AND a subwoofer, replacement of the primary fuel pump might be somewhat easier. We will see.
Btw, any idea where the secondary fuel pump is located? Thanks!
Old May 28, 2019 | 09:37 PM
Dr. D's Avatar
The secondary fuel pump is also located in the fuel tank along with the primary fuel pump.
wayland
Apr 4, 2016 04:03 PM
Swagger XC
Apr 1, 2016 07:49 AM
Awillie
E type ( XK-E )
Mar 29, 2016 04:05 PM
Rabidfox
Mar 29, 2016 08:55 AM
