2003 AC pressure?
Old Jan 25, 2015 | 07:23 PM
brgjag's Avatar
I have always used the cans of "freon" that have the sealer stuff in it.
Old Jan 25, 2015 | 07:32 PM
Gus's Avatar
Gus
The expansion valve is internal to the a/c unit inside the car should this fail the dash needs to come out. Not what you want to have happen.
Old Jan 25, 2015 | 07:35 PM
brgjag's Avatar
if it fails then the only AC I will have is the TOP DOWN.
Old Jan 27, 2015 | 12:01 PM
Cee Jay's Avatar
One thing to watch is that A/C can leak THROUGH the actual hose itself. I tried tracking down my XK8 leak and couldn't find it anywhere, not with dye, compressed air, nothing. It turns out that the rubber low-pressure hose from the low-pressure port at the firewall that goes to the compressor was oozing mostly from the bottom. A mechanic buddy of mine casually wiped the bottom of the hose with a white cloth and showed me the pale green dye with a UV light in a darkened room. It was also covered in the compressor oil, which was one of the reasons he checked there first. I didn't know freon could leak THROUGH a hose.
ryan_border
Dec 23, 2015 04:27 PM
dieseldoc
Sep 28, 2015 01:17 PM
SoCalJagS
Sep 27, 2015 09:20 AM
reb1999
Sep 25, 2015 10:00 AM
fingers
Sep 11, 2015 12:21 PM
