2003 XK8 coolant capacity
Old Mar 16, 2021 | 02:55 PM
Bob Boyle's Avatar
Default 2003 XK8 coolant capacity
Anyone got any idea how much coolant is needed to fill the system; I'm going to be changing, hoses, thermostat and water pump soon?
Old Mar 16, 2021 | 03:29 PM
michaelh's Avatar
Here you go...
edit: You're unlikely to get all the old coolant out with just a drain & fill, so the above quantities will be ample.
Old Mar 16, 2021 | 08:26 PM
rothwell's Avatar
You will only need a couple gallons of Dexcool.
Maybe take a look at my DIY that covers the whole job you are about to do with pics and parts list for 4.2L.
Old Mar 17, 2021 | 05:35 AM
Bob Boyle's Avatar
Any idea where the coolant drain plug is located?
Old Mar 17, 2021 | 11:01 AM
rothwell's Avatar
Bottom corner on passenger side of radiator. After you get the plastics off the underside you will see it.
Old Mar 17, 2021 | 11:44 AM
Bob Boyle's Avatar
Is there a drain plug somewhere on the engine block?
66RBS
Nov 14, 2019 03:45 PM
Ish
Apr 8, 2014 04:51 PM
anthonyisd3ad
Dec 21, 2013 08:31 PM
RidenXj8
Oct 25, 2012 04:35 AM
Peter M
Nov 4, 2010 03:21 PM
