2004 xk8 cooling fans
Old Feb 11, 2023 | 03:31 AM
richimnot's Avatar
Default 2004 xk8 cooling fans
Hello new here. I own a 2004 xk8 /x100. Will a universal cooling fan work in place of oem
Old Feb 11, 2023 | 07:48 AM
zray's Avatar
What is your goal ?
Cheaper replacement part ? More cooling capacity ? Etc ?
Z
Old Feb 11, 2023 | 09:35 AM
richimnot's Avatar
Default dual cooling fan replacement
Originally Posted by zray
What is your goal ?
Z
a cheaper replacement part for my 2004 xk8/xkr/x100 because it looks as though the replacement of the dual cooling fan is far more expensive than 2003 and earlier of the same model will a Universal dual fan work in this model?
Old Feb 11, 2023 | 12:43 PM
fmertz's Avatar
You probably need to investigate what is wrong first. The system is no longer an low/high but continuously variable/PWM (4.0 engines are lo/hi, 4.2 engines are PWM). The controller is mounted on the fan shroud. Try and figure out if the fans themselves are bad (both of them at the same time?) or if the controller is bad. Of course check the fuses and relays ahead of time (jagrepair has the electrical guide).
FWIW, the cooling fan assembly is not particularly known for failing, so a used part might be worth the risk.
Best of luck, keep us posted.
speechdata
Sep 25, 2021 03:30 PM
Spikepaga
Sep 29, 2016 12:11 PM
Finetune45
Jul 4, 2013 10:22 AM
Lanny
Dec 25, 2012 08:03 PM
Mi_barragan
Aug 8, 2010 08:32 AM
