2004 XKR Died while driving/turns over, won't start
Old Apr 22, 2012 | 11:54 AM
XKRowner's Avatar
Cool 2004 XKR Died while driving/turns over, won't start
I am brand new to the forum, now that our XKR has 70,000 miles on her I expect I will be tinkering with it more and more... Thank you in advance for your help.
My wife was driving along and the car slowly died off on her. I initially thought alternator or battery... not the case. The car will turn over just fine although it will not fire off. If I cycle the key a few times it will sputter a bit as it sounds like it almost starts, no luck. I have put a flat in the schrader valve on the drivers side of the engine and I do get a flow of fuel, not a spray as I was expecting?? Any help is greatly appreciated.
Daniel.
Old Apr 22, 2012 | 12:55 PM
XKRowner's Avatar
Just for giggles I hooked up a jump box and cycled the key a few times to allow pressure to build. It almost started again, but no luck...
Old Apr 22, 2012 | 02:15 PM
Reverend Sam's Avatar
I'm thinking fuel pump. As soon as you press in that shrader valve you should get a huge spray of fuel. The first time I did it I get sprayed in the face and all over my shirt. After that I was careful to cover it with a towel of something.
Old Apr 22, 2012 | 03:07 PM
Gus's Avatar
Gus
+1 on the fuel pump. Get a pressure reading http://www.jagrepair.com/FuelPressureTestingxk8.htm
Old Apr 22, 2012 | 03:24 PM
XKRowner's Avatar
Thank you, that was my fear. Dealer only item I am told. I am going to go ahead and do a pressure test as Gus suggested. Appreciate the help.
Daniel
Old Apr 22, 2012 | 03:25 PM
XKRowner's Avatar
I am going to do that. I appreciate you taking the time. I am told the fuel pump is a dealer only item?
Daniel
Old Apr 22, 2012 | 03:54 PM
Gus's Avatar
Gus
I understand other pumps are available but first see if the pump is the problem. It could be a fuel filter or something else. Do you have a check engine light and or do you have a way to check the OBDII codes?
Old Apr 22, 2012 | 04:19 PM
Do the 2003+ XKRs use the same fuel pump as the 2003+ XK8s? If so, I know you can get new fuel pumps on eBay for about $500. I've seen a used one for about $250, but I only saw one that cheap one time. I made a video on removing the tank and fuel pump. It's not that hard, just make sure you make the nifty tool that Avos invented.
Old Apr 22, 2012 | 04:54 PM
IanP's Avatar
I have just replaced my pumps in a 2001 XKR. They cost £160 each from a dealer. If you go to an idipendant you should be able to pick them up for £70 each. Not sure what that is in dollars.
IanP
Old Apr 22, 2012 | 05:40 PM
IanP
Unfortunately in 2003 Jaguar started using a returnless fuel system. The fuel pump is completely different, and it uses control module to rapidly turn the fuel pump on and off to regulate the pressure. The old pumps are not compatible and the new ones are very expensive.
Old Apr 22, 2012 | 06:00 PM
Different part numbers:
4.2 Normally Aspirated: C2N1146
4.2 Supercharged : C2N1147
Doesn't the SC have a higher flow rate?
Old Apr 22, 2012 | 09:17 PM
XKRowner's Avatar
I went ahead and purchased a pressure guage. It didn't register anything with the key on.. So I had my wife cycle the key while I was looking at the, saw a very tiny bump in the needle. Had her try and crank it, saw it go up to maybe 5psi.
I did buy a filter as well along with a tool to remove it. I cannot get the filter off to save my life, I hate to say. Has a white portion close to the end of the connector-- a small band, but it does not go all the way around??
It is so difficult to even reach up to it, kicking my rear...
Old Apr 23, 2012 | 09:37 AM
XKRowner's Avatar
Does anyone know what the tool should look like to remove the fuel filter?
I have a strong feeling I am using the wrong one....
Spoke to Jaguar this morning. They do not stock the fuel pump which tells me they do not go out often. They stated if they replace atleast 3 a year the part will be in stock. No dealer in town (Houston) stocks it.
The filter has some sort of internal clip.....
Old Apr 23, 2012 | 10:09 AM
XKRowner's Avatar
This is what my clips look like (not actual car)
Old Apr 23, 2012 | 10:58 AM
jagjoe's Avatar
You can get a set of clip removal tools at any major parts store. Not expensive
Old Apr 23, 2012 | 02:04 PM
Gus's Avatar
Gus
Go to page 4 and you will see a set of clips http://www.jagrepair.com/images/Auto...eplacement.pdf I do not know the proper size you will need but I am sure one in the package will fit.
Old Apr 23, 2012 | 04:04 PM
XKRowner's Avatar
Thanks Gus, I saw them, unfortunately purchased the scissor type.... Will be back at the parts store tonite. Truly feel like an idiot playing with a fuel filter for hrs.
Old Apr 23, 2012 | 08:40 PM
Gus's Avatar
Gus
Do not feel that way! We all go down that path every now and then but we do not tell anyone!!!!!
Old Apr 24, 2012 | 01:31 PM
H20boy's Avatar
push in on the green insert, then pull apart the filter from within that clamp thingy on the hose. It took me hours to figure out how to get that thing apart.
Old Apr 30, 2012 | 05:19 PM
XKRowner's Avatar
Boy I feel silly. These type of clips only require that you press in toward the line directly on the colored part, then pull apart. You can use the clip removal tools although they are unecessary. You cannot buy new clips for these types, I had to pick up a couple lines that a mechanic had cut off another vehicle and then splice them in with hose clamps.
