4.3 for 4.0
Old Mar 28, 2008 | 03:39 PM
Donnylee's Avatar
Default 4.3 for 4.0
Only just curious....is itcompatible toswapin a4.3 into a earlier19994.0 car? Other then the physicalswap itself? Does the 4.3 share the same harnesses fasteners as a 4.0? I assume there would bedifferent ECM Calibrations. Is it a different generation of ECM for the 4.3?
I know anything can be made to work with the right effort. But had not seen anyone post that swap for a replacement candidateand a smallupgrade at the same time. Other then the Bore/Stroke differences of the two. What else changed that would make it difficult?
Thanks for your thoughts in advance.
Old Mar 28, 2008 | 04:43 PM
Donnylee's Avatar
Default RE: 4.3 for 4.0
No need to respond....I found the some good answers.....Looksto melike 4L cars will stay 4L cars! To much Jaggauge differencesto change and re-fit.
Old Mar 28, 2008 | 09:41 PM
jag_genius's Avatar
and it's a 4.2 liter not a 4.3
Old Mar 29, 2008 | 08:45 PM
FactoryJaguarTech's Avatar
Well....once the valves smack the pistons it could possibly become a 4.3? lol
Old Apr 3, 2008 | 07:11 PM
AJV8's Avatar
Were you planning on using the Aston Martin 4.3 version of the AJ-V8 (that is a bored out version of the original 4.0 rather than the stroked 4.2 jaguar version of the same engine).
I am asking because I am wondering how much commonality there is between Aston Martin and Jaguar ECUs and if you inadvertenly found something out?
aode06
Jul 28, 2023 02:26 PM
hoodun
May 15, 2019 09:31 PM
mat32essex
Oct 3, 2015 04:12 PM
pnwrs2000
Sep 30, 2015 01:56 PM
Gregory Neil O'Rear
Sep 29, 2015 09:52 AM
