97 vert electrical issues
Old Jul 27, 2017 | 11:05 PM
Papadog's Avatar
Default 97 vert electrical issues
I'm thinking I have some ground issues
1. Some times the windows drop down when opening the door but does not go back up
2. Some times the windows do not go down when opening the door
3. Some times when removing the key there is no electrical functions for several minutes (during this event if I try to crank the car no accessories work and the panel lights are dim, like the battery voltage is very low) after a few min everything works fine
4. Once when on a errand I restarted the car and got the transmission fault message after restarting again no issues
5. Some times when idling the voltage goes low ~9volts abs light illuminates the voltage comes back and abs light goes out
6. Some times while driving ABS light illuminates and I get ABS and Traction messages, after restart no issue
Not sure if any of these are related but suspect poor grounds, any help would be appreciated!
Thanks, Papadog
Old Jul 27, 2017 | 11:47 PM
grantorino62's Avatar
I presume the battery is less than 4 yrs old? I assume you've removed the battery cables and cleaned them and the battery posts? I assume you've verified no loose connection at the alternator prior to posting? My first thought is a loose positive post on the alternator. Did you, on purpose, misspell Alabama?
Old Jul 28, 2017 | 06:26 AM
RJ237's Avatar
Check the ground from the bell housing to the chassis and the connections to the bulkhead fittings, also the two big fuses in the trunk.
Old Jul 28, 2017 | 08:41 AM
Papadog's Avatar
grantorino62, battery is 7 months old, battery terminals are clean, did not check alternator connection, thanks I'll check it. I've transposed letters before, not sure how I transposed the a and m keys...
Old Jul 28, 2017 | 08:42 AM
Papadog's Avatar
RJ 237, will do thanks!
Old Jul 29, 2017 | 08:53 PM
brgjag's Avatar
classic 97 main computer issues? Multi error messages and going on's that do't make any sense and go away by turning car off and on.
Old Sep 21, 2017 | 07:33 PM
Papadog's Avatar
Well I cleaned up several grounds and checked the alternator connections. The conditions have been corrected. I took the bad kitty to Barber's Vintage Motorsports Museum in Birmingham (Alabama), about an hour and a half drive each way, and it performed perfectly! Thanks for all your suggestions!
