abs brakes
Old Jun 11, 2014 | 02:17 AM
tony bosco's Avatar
Cool abs brakes
hey forum, thanks for all the info. on the abs. just put car in body shop today, some rat b------ keyed the whole side of my car. will check abs wiring harness and sensor and also pick up the ctek when i get the car back in a few weeks....... is there any way to pin point which wheel might be bad (sensor/harness ) or just inspect all of them ? thanks again tony b.
Old Jun 11, 2014 | 02:46 AM
jimbov8's Avatar
Sorry to hear about the damage Tony.
The best thing to do is to go around all 4, that way you will know they are all clean with good connections. You could check the resistance of each circuit but with an intermittent fault you would be hard pressed to find it.
Try the cleaning and connectors first and with a fully charged battery, see how you go from there.
Old Jun 11, 2014 | 09:33 AM
tony bosco's Avatar
Cool abs brakes
will do...in a few weeks anyway... thanks
ericjansen
Dec 19, 2021 12:20 AM
British Ride
XJ40 ( XJ81 )
Nov 28, 2015 03:50 PM
flyrr100
Sep 29, 2015 03:47 PM
xjrjag
Sep 24, 2015 10:08 PM
