2003 X-Type, No ABS Or brake Light On Instrument Cluster
Old Sep 21, 2015 | 10:54 PM
xjrjag's Avatar
Default 2003 X-Type, No ABS Or brake Light On Instrument Cluster
Just purchased a 2003 X-Type 2.5L AWD. It's a bit different than my XJR...there are some things that need attention. One of them is the ABS and BRAKE light on the instrument cluster. When the parking brake is pulled up, the red BRAKE light does not illuminate on the dash. There is no information center on the cluster, just a spot where the odometer and trip counter are.
When I turn the key to the ON position, all of the lights on the dash SHOULD light up briefly...this does happen, however there is no BRAKE light and no ABS light that illuminate. The brakes work properly (or seem to anyway)...the parking brake works as it should...just these two lights never illuminate on the dash.
It COULD be that coincidentally both of these bulbs burnt out in the cluster itself, but that is HIGHLY unlikely. I think there is some sort of fault going on here. Has anyone experienced this or know what the cause is? Thanks in advance, as any help is appreciated!
Old Sep 24, 2015 | 11:14 AM
Larry-Cleveland's Avatar
I have seen odd things with the lights to find out that the last owned covered up the lights with tape or put burned out lamps in to hide problems....some people.
I hope your luck is better then mine.
Old Sep 24, 2015 | 11:17 AM
xjrjag's Avatar
Took the cluster apart and the SOB put electrical tape over both bulbs. Now to diagnose why those lights are on. Most likely faulty ABS module
Old Sep 24, 2015 | 11:36 AM
My SOB just did not tell me the lights were on when I asked.
So they just happened to come on when the car was shipped to me...Right!
Old Sep 24, 2015 | 10:08 PM
xjrjag's Avatar
I had checked over the car thoroughly before purchasing, and I even checked to make sure the bulbs were all working with the key in the ON position. However, my main concern was that the check engine light illuminated...never registered that the ABS and BRAKE light were missing. When I asked the guy about it, of course he denied it and said that he never had a problem and that the tape "must have been there for a long time". That's funny because the top of the gauge cluster was dusty, except for where someones fingerprints are.
Shawn Svacha
Nov 4, 2019 02:47 PM
PMKimpton
Aug 3, 2019 08:22 PM
laserguy
Sep 3, 2015 02:02 PM
OkieTim
Sep 2, 2015 12:48 PM
innzane
Sep 2, 2015 10:08 AM
