ABS module
Old Aug 22, 2016 | 10:26 AM
98 shadow's Avatar
Default ABS module
Trying to get the ABS module out, E5 reverse torque no problem but windshield washer neck in the way. Has any one removed this and how (windshield neck)
2001 XKR
Old Aug 22, 2016 | 12:14 PM
RJ237's Avatar
The neck just needs a twist to remove. Many have claimed they bend the brake lines out of the way, but I prefer to disconnect. If the system has not been flushed in the last two years you should do that also, so getting air in the system is not a problem.
Old Aug 22, 2016 | 12:43 PM
Gus's Avatar
Gus
I recently pulled my ABS 4 mounting bolts, 1 plug and 4 bolts holding the control module in place. The removal of the mounting bolts allows you to move things without any serious bending.
Old Aug 22, 2016 | 06:00 PM
98 shadow's Avatar
many thanks. I love this place as much as the car,maybe.
