ABS Module
Old Feb 3, 2017 | 10:21 AM
terry73's Avatar
Default ABS Module
Does anyone know any trick to get the large plug back into the module without bending any of the small copper pins, I have hours of attempts.
Old Feb 3, 2017 | 10:55 AM
RJ237's Avatar
It would help if you put the year/model in your signature (open user cp in black bar).
Assuming it's a XK8, the lock for the plug is a black rectangle directly above the socket. Is it pulled up?
Old Feb 4, 2017 | 11:20 AM
DevonDavid's Avatar
Read through this - it helps to "visualise" RJ237's advice although not the same car.
https://www.jaguarforums.com/forum/x...75-code-70004/
