Abs , tracc failed
Old Jul 4, 2012 | 05:50 PM
tanngo's Avatar
Default Abs , tracc failed
sometimes the abs light, traction failed, when I do a windows, mirrors, electric consumer. Recent new battery charged. abs sensor is ok. sorry for language.
Old Jul 4, 2012 | 08:09 PM
RJ237's Avatar
http://jagrepair.com/images/AutoRepa...heet%20XK8.pdf
This is a good start. My own resistance readings were 1.1- 1.2 Kohm. You really need to get the abs codes read. If you have a abs pump circuit failure it probably means the abs module needs to be rebuilt.
RJ___________________
97 XK8 Conv. 85K mi
Old Jul 4, 2012 | 09:02 PM
tanngo's Avatar
Thank you, after 30 seconds, message disappears
run after reset ,
Old Jul 5, 2012 | 03:16 AM
Is it definitely a 'TRACTION CONTROL FAILED' constant amber warning message being displayed and not the flashing 'TRAC' message to show when it's operating?
( please add vehicle details to your Signature - everyone who reads this thread will have to check through your previous posts to find you have a 2001 XKR )
Old Jul 5, 2012 | 10:33 AM
Richy_T's Avatar
First thing to check is the sensors. But it appears that more likely items are the cables (wires broken) and the ABS module (PCB traces cracked).
Mine was the abs module. $6 job to repair.
Old Jul 5, 2012 | 11:56 AM
tanngo's Avatar
HELLO, THANK YOU, LITTLE ENGLISH. AMBER LIGHT TURN ON AFTER CHARGING BATTERY, SOMETIMES, when you restart off.
jaguar xkr 2001 . 30.000 km argentina-
aode06
Jul 28, 2023 02:26 PM
goges
Oct 5, 2015 04:53 PM
millertic
Sep 30, 2015 08:11 PM
leep123
Sep 30, 2015 03:41 PM
mrplow58
Sep 30, 2015 08:56 AM
