AC Ports??
Old Aug 28, 2011 | 04:32 PM
TxToast's Avatar
Default AC Ports??
Looks like the AC ports are in the very front right and very rear roughly dead center. Having looked at both caps I'm not sure which is the low pressure port. I'm used to having a clearly marked "L" and "H"...also these are plastice and I'm used to aluminum so its entirely possible I'm looking at the wrong thing....which is why I'm posting
Old Aug 28, 2011 | 05:35 PM
Paul Pavlik's Avatar
The Rear Port (Near the Firewall) is the LOW Pressure Port. The diagram in the Nigel Thorley Book is WRONG!!
Old Aug 29, 2011 | 12:41 AM
alabbasi's Avatar
The low side port is usually attached to a much thicker hose then the high size. This is usually the give away.
Old Aug 29, 2011 | 09:25 AM
This is from 1997 XK8 Specs:
aarahim
Aug 31, 2021 11:04 AM
ziondio
Oct 1, 2015 01:48 AM
reb1999
Sep 25, 2015 10:00 AM
bigmikeyt
Sep 14, 2015 12:06 PM
